LED voltage drop
Discussion in 'General Electronics Chat' started by samjesse, Aug 21, 2009.
  1. samjesse
    Thread Starter Active Member
    Sep 14, 2008
    202
    Hi
    I am connected a 6v battery (4x1.5 AA) to a LED an took the voltage reading across it. I expected to read 2v but it read 5.65v. can some one tell me why? isn't suppose to maintain a 2v drop across it?
    thx
  2. peranders
    May 21, 2007
    87
    You must put a series resistor into the circuit otherwise you will distroy the poor LED.
    I = desired current which is 2-10 mA for normal LED's.
    Uled is 1.6-1.8 for red LED's
    Yellow and green has somewhat higher values
    Blue has 3-4 V
    R = (Ubat-Uled)/I
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
  4. mik3
    Feb 4, 2008
    4,846
    63
    You read 5.65V because the LED has burnt.
    It will drop about 2V (depends on the LED colour and temperature) if it is operated at its rated current.
    Thus for a LED which drops 2V and operates at 20mA you will need a (6-2)V/20mA=200 R resistor in series with the LED for a 6V supply.
