led tube
Discussion in 'The Projects Forum' started by Lightfire, Mar 7, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    Is that the led tube you are suggesting to me. >>>>>>>http://www.aliexpress.com/product-fm/370338809-SMD-led-tube-DC12V-Superbright-led-tube-wholesalers.html<<<<<<<<
    Thank you.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Huh? What? Que?
  3. Lightfire
    Oct 5, 2010
    690
    21
    Um, never mind.
    So I will ask it again.
    Is led tube like that, on the picture? or not?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    If you are posting a link, you either need to use the "Insert Link" tool (globe with chain link) or leave a space before and after the link. If the link is a long one (like yours is), you really should use the "Insert Link" tool or the URL might get chopped off.
    Like this: SMD led tube,DC12V Superbright led tube
    Those might work, but there are no specifications given (which is a big concern), and the minimum number you can buy is 1 lot (12 tubes) for $338.98 USD, or roughly 14,667 PHP
