LED to trigger relay?
Discussion in 'The Projects Forum' started by My Tech Guy, Feb 18, 2009.
  1. My Tech Guy
    Feb 18, 2009
    15
    Hi, we are trying to use a LED (from a car alarm) to trigger a relay. My guess is that the LED will operate around ~10mA and will be under powered to use as a trigger. I was told that I would need to use a bipolar junction transistor between the LED and the relay. Does this sound feasible? If so, what would be a good transistor (part number) to use, and how would we wire it to both the LED and the relay? Thanks.
  2. italo
    Nov 20, 2005
    205
    A relay usually means a bit of power to operate. a led is a a source of light that you must transform into a electron flow. so now you need a photo diode to sense it or other means of detecting photons or light. there is plenty of info on that on the internet.
  3. My Tech Guy
    Feb 18, 2009
    15
    I'm just interested in the coil side of the relay. True, a photo diode would work, but wouldn't be feasible for our application. We are interested in only electrical means of modifying the LED to work with a relay. Thanks.
  4. mik3
    Feb 4, 2008
    4,846
    63
    A led can act somehow like a photodiode but it may not have enough sensitivity.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Yep, it will require oodles of gain. A LED is reversable as a *very* weak photocell, but there are better ways. Why an LED?
