LED to indicate activity on a USB port
Discussion in 'Embedded Systems and Microcontrollers' started by Ali.Soliman, Oct 2, 2012.
  1. Ali.Soliman
    Sep 14, 2012
    5
    Hi guys
    I am trying to use an LED to indicate activity on a uUSB port (flashing)
    I used a FET (FDV301N) connected to the VBUS and then to the LED
    Will this work?
    Is the VBUS always 5V when a USB device is connected or does it change value while device active/inactive.
    I attached a screenshot of my circuit.
    thanks you.
      File size:
      28.6 KB
      51
  2. ErnieM
    Apr 24, 2011
    7,445
    1,628
    VBUS is always 5 volts when plugged into the host. It's there to power your slave device.
    To indicate activity you have to add some code into your device (plus a pin to drive the LED).
    Ali.Soliman likes this.
  3. MrChips
    Oct 2, 2009
    12,656
    3,461
    When a USB device is plugged in, there is always activity on the bus.
    The USB controller constantly interrogates the device.
  4. Ali.Soliman
    Sep 14, 2012
    5
    Thank you guys.
    I appreciate all your help.
    Cheers.
