Hi all, thank you in advance for your help in these simple projects that i need help for...
I beg your pardon in advance that I am not from electrical field and a complete novice in this, so any help is hugely appreciated..
Ok this is what I need:
I have 1 LED(small 3mm LED), that will be powered by 3 1.5 volt button cells and 1 switch.
What i need-
1. After a switch on the LED, it automatically switches off after 2 minutes.
The circuit needs to be really simple and small, overall it should fit into a tube 17-18mm in diameter.
2. After switching on, the LED fades-in to full glow in about 30 secs and stays in full glow till switched off. again, overall it should fit in a tube 17-18 mm in diameter.
3. How can i make the LED blink or pulse while its on?
I know i am asking for too many solutions in 1 go but i really really need the help..thank you all...
What i need-
