LED Tester
Discussion in 'General Electronics Chat' started by RodneyB, Feb 2, 2015.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    652
    14
    With all the new LED's available with forward voltages of 3 volts or more the diode tester on a multi meter is no longer suitable for testing these components.
    Can someone suggest a suitable circuit for testing these or a method.
    Many thanks Rodney
  2. MrChips
    Oct 2, 2009
    12,636
    3,455
    A 9V battery and a 1kΩ series resistor or
    two 1.5V batteries and a 220Ω series resistor.
    RodneyB likes this.
  3. wmodavis
    Oct 23, 2010
    737
    150
    A lab power supply with adjustable voltage and current, digitally metered outputs of same, RS232 input for computer control of V & I with data logging capability.
    RodneyB likes this.
  4. Bernard
    Aug 7, 2008
    4,240
    414
    Best to use the higher V, 9 V or 12 V, with 470 to 1 k ohms in series with LED; add 2 red LED in series across test terminals. With no LED in test or a reversed LED, red LED's will be on. With correct polarity , test LED will light, reds off. With reversed test LED V will be limited to about 5 V which is usually safe for LED.
    wayneh and RodneyB like this.
  5. crutschow
    Mar 14, 2008
    13,502
    3,376
    The simplest circuit for a functional test would be as Mr. Chips suggested except I would use three 1.5V batteries in series with a 220Ω instead of two, to insure there is sufficient voltage for the higher voltage LEDs.
  6. mcgyvr
    Oct 15, 2009
    4,791
    976
    As the ranges of VF's and current ratings between LEDs are vastly different than they were a few years ago stating a supply voltage level and resistance is mostly pointless here..
    3 x 1.5V or 1 x 9V or 1 x 12V batteries ain't gonna do squat if the LED's Vf is greater than that.
    Ideally the "tester" would have a voltage exceeding the Vf of the LED (could be 9V..could be 12V... could be 30V,etc...) and sufficient current to allow a visual level of illumination.
  7. #12
    Nov 30, 2010
    16,704
    7,354
    I believe we did this a few days ago. Same TS, same question.
  8. wayneh
    Sep 9, 2010
    12,391
    3,246
    Déjà vu all over again?
  9. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  10. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    Some people favour the "joule thief" blocking oscillator/inverter - if you don't like winding coils, you can cross-connect the parallel inductors in a common mode choke from a small SMPSU such as in a scrap set top box.
    Another favourite is the well known astable oscillator with a 470uH choke as one of the collector loads.
    Both options run on a single 1.5V cell and rely entirely on inductor back emf to make the LED Vf.
  11. wayneh
    Sep 9, 2010
    12,391
    3,246
    Get a different multimeter. My free Harbor Freight meters work fine for LED testing. They glow dimly - probably 1mA or so.
