LED tape light config, fuse, wire gauge?
Discussion in 'The Projects Forum' started by Bassist58, Jan 5, 2013.
  1. Bassist58
    Dec 16, 2012
    5
    I recently purchased (on ebay) a "Kitchen Cabinet Counter LED Tape Lighting 16 ft Strip SMD3528 300 LED WARM WHITE" to use as a lighting system in my shed. It is 12V, but that is all I know. I don't know how many watts or how much current.
    I plan to power it with a 12v deep cycle battery (not yet purchased).
    Now, from the battery+, I want to use a fuse (inline), a switch (spst), then the tape light and back to battery-. Is this a good config?
    If so, what fuse (amp wise) and what gauge wire (running less than 50 ft.) would be recommended?
    Thanks in advance,
    Brian
  2. tubeguy
    Nov 3, 2012
    1,157
    197
  3. Bassist58
    Dec 16, 2012
    5
  4. tubeguy
    Nov 3, 2012
    1,157
    197
    These appear to be the same items. If so, then the stated current rating is 2 amps, so a 3-4 amp fuse would work. Never go too large on a fuse!! 18 gauge lamp cord would be fine.
    Looks like you got a good deal !!
  5. Bassist58
    Dec 16, 2012
    5
    Thank you for the info.
    I actually got a better deal than that as they sent me 2 by mistake!
    Brian
