LED tachometer help
Discussion in 'The Projects Forum' started by BlueIceVirus, Jun 2, 2010.
  1. BlueIceVirus
    Jun 2, 2010
    Im trying to make a tach with an LED output display of 20 LEDs. I have scanned through tons of posts and cant seem to find the info I need. Im rather new to electronics, though Im rather a DIY person. Can some one help me design a circuit. 4 cyl engine, looking for a res of 500rpm over 20 LEDs. I did find one circuit as a ref. but not sure if it would fit my application.:confused:
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    That's about the circuit that you want, if you are going to avoid microcontrollers.
    Unfortunately, unless you have a good bit of test equipment around, you will have no way to calibrate it to make sure that it is accurate.
    If you used a microcontroller, you would know it was within about 1% accuracy, even if it did not use a crystal for a time base.
  3. BlueIceVirus
    Jun 2, 2010
    Would you be willing to walk me through one?
  4. eng1ne
    Member
    Dec 4, 2009
    97
  5. BlueIceVirus
    Jun 2, 2010
    Thanks for the link, will take a look and get back to you :)
