LED switch
Brian Krupicka
Joined Nov 1, 2014
38
I have a need for a simple SPDT type switching system to power LED’s on a signal bridge for my model railroad.
12V DC input and 12VDC on/off output 1 and 12VDC off/on output 2.
Any assistance would be helpful.
Brian
Dr.killjoy
Joined Apr 28, 2013
1,196
What do need assistance for ??? You make the center tap +12 and the right side use one row for on and the other is off .. The left side do the same but opposite..
Just remnber the current limiting resitors for the LEDs
Brian Krupicka
Joined Nov 1, 2014
38
Please explain what you want cause we are trying to help and you are changing your mind and making this very difficult..
I would like a circuit that:
When you have 12VDC on the input, output one would be on and output two would be off
When there is no 12VDC on the input, output one would be off and output two would be on.
Normal SPDT type swicthing but using transistors or IC's not relay contacts or standard switches.
Brian
djsfantasi
Joined Apr 11, 2010
9,163
What's controlling the presence or absence of 12VDC to this circuit? If 12VDC is absent. what is the input connected to?
How many of these LEDs are you going to light in total?
Is 12VDC the only power source available? What is supplying the power (e.g., is it a DCC power supply, booster or traditional model RR power pack)? How much current can it supply?
There are several ways to accomplish this, but we need to know more about the environment. If you could answer the above questions, adding as much detail as possible to cover the questions I might ask...
Brian Krupicka
Joined Nov 1, 2014
38
RESPONSE: TWO.....ONE PER STATE
RESPONSE: 12VDC NOT DCC ....AS FOR AMOUNT OF POWER, I HAVE A PC TYPE POWER SUPPLY FOR DC OPERATIONS AND LIGHTS. THERE IS MORE THAN ENOUGH FOR TWO LED's.
RESPONSE: The triger (Switch) for the light bridge is a AZATRAX detector.
djsfantasi
Joined Apr 11, 2010
9,163
Another way, using ICs, is to use flip flops. In particuar, a toggle or T flip flop.
The schematic below uses a JK flip flop from a CD4027 package, wired as a T flip flop. The input is split on the left, one branch going to the J input and a second going to an inverter from a CD4049 package and then to the K input. This is how to make a T flip flop from a JK flip flop. Clock, Preset and Clear are all unused and tied to ground.
The Q and Q bar outputs are your toggling signals. The IC can't source/sink enough current to light the LEDs, so we use an NPN transistor buffer.
This circuit is presented as is, as I cannot test it right now. But you should be able to get some ideas from its construction. Note that each CD4027 package contains two flip flops and the CD4049 package contains 6 inverters.
ScottWang
Joined Aug 23, 2012
7,409
About two years ago that I designed the similar but a little different circuit used two methods, one was bjt and another one was just used one 74LS05, as the circuit that I attached, it needs to use 74LS05 to replacing the 3 bjts circuit.
djsfantasi
Joined Apr 11, 2010
9,163
Remember his circuit must operate in a 12VDC environment. The 74lsxxx series don't have a broad enough operating range, which is why I went with the CD4000 series.
