LED switch status indicator
Discussion in 'The Projects Forum' started by deanspy, Jul 2, 2006.
  1. deanspy
    Jul 2, 2006
    Hello folks,
    I have a circuit that uses a DPDT switch to choose two possible audio paths. I would like to add an LED(s) to show which path has been chosen. Yes, I could use a 3PDT switch, but I would rather not. I cannot modify the wiring of the switch, as the two paths (+ and - of a balanced microphone running phantom power) must be switched as-is.
    The solution must not colour the audio in any way.
    Any thoughts would be most appreciated
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    You can try a resistor on one path going to the LED and completing circuit Since the circuit is using phantom power it should light. It may however interfere with the audio. YMMV
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    The LEDs could be driven by opamps. Since opamps have high input impedence, they should not interfere with fidelity.
    A modification of the "bar graph generator" in this tutorial should work: http://www.allaboutcircuits.com/vol_3/chpt_8/3.html
    Note that the LEDs would only light when a signal was present. One would still have to look at the switch when no input was present.
  4. mozikluv
    Jan 22, 2004
    1,437
    how about using 2 DPDT. the other pole to take care of the audio path and the other pole to power up your LED. that way there is no audio interference.
    moz
  5. deanspy
    Jul 2, 2006
    Thanks people!! I'm thinking I might "merge" your thoughts and use 2 small DPDT relays controlled by a single SPST pushbutton.
