LED Stage Light Capable of Control via DMX512
Discussion in 'The Projects Forum' started by Anna1, Nov 23, 2012.
  1. Anna1
    Nov 23, 2012
    I'm having a problem with this circuit. I am trying to get an LED wash light circuit to be remote controlled via DMX512. The problem is, after I found the circuit for the RS485 (which will deliver the DMX signal to my LED circuit) my professor told me that there's no time to make it and that I should just buy it. I couldn't find a descent one to buy. I am also not sure if I should connect the LEDs with parallels or using a darlington pair? ! I have attached the circuitry for the RS485. Also, the options I have to connect the LEDs, not even sure which Microcontroller is the best for them. Any help? It's also 5 - 9 LEDs.
    I really need the help on the best method to design the LED circuit, since my previous one was rejected by my advisor. Also, can I please get a website link that I can buy a read RS485 from? :) any help with the LED circuit would be appreciated.
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    Anna1 likes this.
  3. JDT
    Feb 12, 2009
    658
    85
    If you want to make something, I would suggest a PIC. Code to receive DMX can be found here:-
    http://www.qsl.net/n5tle/dmx2avc.asm
    You could adapt this code.
    Couple the DMX (which is RS485) to the PIC like this:-
    http://www.qsl.net/n5tle/dmx2avc.pdf
    Look at the connections around IC2.
    I would control the brightness of the LEDs using PWM. Fairly easy to do in PIC software. Some PICs have a limited number of PWM peripherals built in.
    The simple way to drive the LED would be a logic-level MOSFET and a series current limiting resistor to control LED current.
    Anna1 likes this.
  4. Anna1
    Nov 23, 2012
    Bertus, Yes I got it from there. Unfortunately I was asked not to do it, and to buy a ready RS485 (do you have any idea where to buy a good one?). I have looked at the bottom of whereas the 3 circuits, I just couldn't figure which was suited until I first find the new RS458 I'm about to buy. Thank you for your help.
    JDT , I will defiantly have a look at those sites. I really appreciate your help. Thanks a million.
  5. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
  6. tubeguy
    Nov 3, 2012
    1,157
    197
