If the LED resistor is 1k then a 1.8V red LED will have a current of about 7.1mA which is not bright.
For a saturated collector current of 7.1mA the base current should be 0.71mA.
When the base resistor is 5k then its input must be 36V to produce a base current of 0.71mA. A peak voltage of 36V (81W RMS into 8 ohms) from an audio power amplifier will destroy the base-emitter diode of the transistor since its maximum allowed reverse voltage is only 5V.
If driven from an ipod headphones jack then the peak voltage is only 2V full blast and the base resistor should be 100 ohms to 180 ohms.
The audio signal is AC but the transistor and LED operate from DC. Then the AC signal lights the LED only half the time which causes it to be dimmed with an avberage current of only 3.5mA.
