Do you mean the pin assignments? The OR gate comes in a quad package. It's name is@djsfantasi I guess my main question with the OR gate, or I guess that specific OR gate, is what is the arrangement for the pins? It's still a little fuzzy for me.
I like this idea so much, I used it in an updated design. I'll attach it later. But don't you mean the third SW press? Counting presses:Might also free up reset by connecting count out 3 to ckock enable; fourth SW pulse then would leave all LED's on untill reset.
Oops, I didn't mean the 4001 obviously. I meant the 4071, but as Bernard pointed out the pinouts are the same. I've edited the original post.I think you could eliminate the 4049 IC: just use the fourth gate of the 4071 IC in the clock-debounce part instead of the two 4049 gates.
BTW, the 4001 contains NOR gates; not OR gates (which would require a reconfiguration of the circuit).
I was wondering what you thought about this?Bernard - is the last OR gate necessary? Is it used to drive the LED or can it be omitted? If so, then one 4071 can be used for two circuits. Thus in the TS example, one PCB can be used for each "team"
