I'd like to use 16 LEDs, 3mm or 1.8mm preferably instead of 8 5mm. Meaning each of the current LED outputs would be power an additional LED. Is this possible? This PCB appears to be using a 16F688 PIC an I can't identify any of the other parts. It can be powered by 3-12 volts.
This is the board:
Link to product: http://www.onlineauction.com/index....n_id=984076&title=Led_Chaser_Sequencer_YELLOW
Thank you.
This is the board:
Thank you.
