LED Sequence Help Needed
Discussion in 'The Projects Forum' started by P4 Modeller, Apr 7, 2013.
  1. P4 Modeller
    Apr 7, 2013
    10
    Firstly i am a complete novice at electronics which will probably account for why i am struggling to make my idea a reality.. so here i am begging cap in hand after some assistance.
    My project is to construct this
    Which thankfully is 95% sorted
    However as part of a much larger control panel I need to build 3 separate "sequence panels" that will enable the operators to know what is happening elsewhere.
    So i need to accomplish the following
    Operation 1 :- 1 x push button (switch 1) to illuminate 2x LED's (amber)
    Operation 2 :- 1 x push button (switch 2) to illuminate 2x LED's (green)
    Operation 3 :- 1 x push button (switch 3) to illuminate 1x LED (green)[seperate LED]
    The hard bit is they need to be sequenced such that
    (a) Switch 1 cancels Switch 2, illuminates 2 Amber LED's
    (b) Switch 2 cancels Switch 1, illuminates 2 Green LED's extinguishes 2 Amber LED's
    (c) Switch 3 illuminates Single Green LED and extinguishes all others LED's.
    The rest of the control panel works on 12v dc and i am using 3mm LED Forward Voltage (V) : 2.0 ~ 2.2, Reverse Current (uA) : <=30.
    I am currently using this circuit elsewhere on the panel and it was wondering if it could be adapted to achieve the above requirements
    If not then i have the ability to construct a newly designed PCB to meet these requirements
    Thank You for looking and in advance for the responses
    Mark
    [​IMG][​IMG][​IMG]
  2. P4 Modeller
    Apr 7, 2013
    10
    Ok Time to Bump My Post... NO Solutions Yet :eek:
    I've come up with one though not entirely as i want but ...
    With Switch 1 (push to make) pressed, the relay is energized and the relay sets a path for the Amber LED's (D1 & D2) to illuminate :)
    [​IMG][​IMG]
  3. P4 Modeller
    Apr 7, 2013
    10
    When Switch 2 (Push to break) is pressed the relay de-energizes and the Amber LED's Extinguish and the Green LED's (D3 & D4) illuminate
    Sorry no way to make relay contacts move in circuit above :(
    Problem is how do i achieve this with 2x Momentary SPST Push button switches OFF (ON)??????
    [​IMG][​IMG][​IMG]
  4. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Hi Mark. I read your posts and I'm confused in what you are trying to accomplish. Let's forget colors, just talk about outputs where any output can have any bulbs, LEDs, buzzers, whatever wired to it.
    Does your system just need 3 outputs?
    Is there a condition where all outputs are off? (I'm counting "states.")
    Are there 3 separate push buttons?
    Are all the buttons located together or at different stations?
    You have an a,b,c where switch 1, then 2, then 3 are pressed. What if they are pressed in different orders?
    I don't think you have a very complex sort of problem. If we can understand what you need we should have tons of suggestions.
  5. P4 Modeller
    Apr 7, 2013
    10
    Hi Ernie,
    Sorry to confuse you, i tried to simplify the problem by splitting the requirements to the bear minimum but it turns out i have done the opposite so i will start again.
    It may help to know there are 3 operators, each controlling one section (up fiddle, main and down fiddle) . Always driving the train towards them (end to end layout) There are two distinct running lines in each section (up and down)
    There will be 3 control stations now labelled Up Control Station ,Main Control Station and Down Control Station. The Main control station is then divided into 2 further mini control stations, for my ease i have labelled these with Identifiers starting B or C )
    Up Control Station
    Switch AA controls output 1 (Down Train Ready) (Amber LED's)
    Switch AB controls output 10 (Up Train Accept)(Green LED's)
    Switch AC controls output 12 (Up Fiddle yard Road Clear) (Green LED)
    Switch BB controls output 2 (Down Train Accept)(Green LED's)
    Switch BC controls output 4 (Down Mainline Ready for Next Service)
    (Green LED)
    Switch BD control output 9 (Up train ready) (Amber LED's)
    Switch CC controls output 3 (Down Train Ready) (Amber LED's)
    Switch CD controls output 8 (Up Train Accept) (Green LED's)
    Switch CE controls output 11 (Up Mainline Ready for next service)
    (Green LED)
    Switch DD controls output 5 (Down Train Accept)(Green LED's)
    Switch DE controls output 6 ( Down Fiddle Yard Road Clear)
    (Green LED)
    Switch DF controls output 7 (Up Train Ready)(Amber LED)
    Outputs 1-6 relate to Down Line
    Outputs 7-12 relate to Up Line[​IMG][​IMG]
  6. P4 Modeller
    Apr 7, 2013
    10
    Hopefully this might explain the control panels
    Red = Up Control Panel
    Blue = Main Control Panel
    Green = Down Control Panel
    [​IMG][​IMG]
  7. P4 Modeller
    Apr 7, 2013
    10
    [​IMG][​IMG]
  8. P4 Modeller
    Apr 7, 2013
    10
    Down Train Sequence
    1.
    Push Switch AA (Output 1)
    2. Push Switch BB (Output 2 : Cancels Output 1)
    Either
    3.
    Push Switch BC (Output 4 ; Cancels Output 1 & 2)
    restart sequence 1, 2 then to 4
    Or
    4.
    Push Switch CC (Output 3)
    5. Push Switch DD (Output 5 ; Cancels Output 3 & 6)[output 6 pre requiste for Switch DD]
    6. Push Switch DE ( Output 6 ; Cancels Output 3 & 5)
    I'd like this to happen without having to re-visit a switch to cancel the selection
    [​IMG][​IMG]
  9. P4 Modeller
    Apr 7, 2013
    10
    UP Train Sequence (actually a mirror of the above in opposite direction)
    1.
    Push Switch DF (Output 7)
    2. Push Switch CD (Output 8 ; Cancels Output 7)
    Either
    3. Push Switch CE (Output 11 ; Cancels Output 7 & 8)
    restart sequence 1,2 then to 4
    Or
    4. Push Switch BD (Output 9)
    5. Push Switch AB (Output 10 ; Cancels Output 9)[output 12 pre requiste for Switch AB]
    6. Push Switch AC (Output 12; Cancels Output 9 &10 )
    [​IMG][​IMG][​IMG]
  10. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I see a lot of broken images in all of your posts.
    If you want to show images, please upload them to this forum.
    Bertus
  11. P4 Modeller
    Apr 7, 2013
    10
    ?????????? Er i See Images that aern't broken ???????????
    Ive logged in and logged out twice aswell ?
    [​IMG][​IMG]
  12. P4 Modeller
    Apr 7, 2013
    10
    Image From Post 1
    Image From Post 2
    Image From Post 3
    Image From Post 6
