Correct me if I'm wrong. A generic 20mA LED has a max safe reverse voltage of only ~5V. In a system with higher voltages, even a resistor to limit reverse current to, say, 1mA will still not protect the LED. If it breaks down at all, it's toast. Is this right?
Such an LED can be protected by adding a normal diode in series with it. [UPDATE: reverse parallel is better]. Using a 1N4007 would protect the LED at voltages approaching 1000V. The arrangement of the two diodes with respect to each other doesn't matter as long as they're in series. Right again? (I have no intention of doing that, I'm at 12V, just making a point.)
