I'm looking to "relay" a small LED into a much brighter LED array, so that when the small LED comes on, the LED array lights up.
Use case:
My legally blind brother-in-law has an answering machine; this answering machine has a small red LED that blinks when the answering machine has a new message. The problem is, he can't see that little blinking LED (especially since it's red, and what vision he does have is least sensitive to red), and needs something much bigger/brighter/bluer to be able to see it from any distance further than sticking his face on the machine.
The simple solution would be just to replace that LED with a transistor that directly drives the bright LED array. The problem is, he loves his answering machine and knows how to operate it by touch, and is afraid to have me open it up and run *any* risk of possibly breaking it.
I'm thinking I could use a photodiode that could be stuck to the answering machine's LED with double-sided tape or some other semi-permanent fixative, then use that to drive a circuit that makes the LED array blink.
I found this circuit via Google:
http://www.circuitstoday.com/photo-relay-circuit
As far as I can tell, D1 would cause the transistor to switch off (disconnecting the circuit) when light hits the photodiode; to reverse this behavior, would it be safe to put D1 on the other side of the base of Q1 (between it and R1)?
Thanks!
Use case:
Thanks!
