Hello Circuit Builders,
I'm a scale model builder and have just begun to add LED lighting to my models.
I am constructing a vehicle with a set of external spotlights using white LEDs. The viewer is meant to be able to press and hold a spring loaded switch which will illuminate the LED spotlights over a span of about 1 second, as if the lights were incandescent bulbs.
When the switch is released, the spotlights should extinguish over roughly the same 1 second time span.
I've found a few examples of similar type circuits here on the forums, but nothing to exactly match what I need.
The model needs to be lightweight and portable and thus will be powered via 11.1 volt LiPo battery hidden in the base. The LEDs I'm planning to use operate at 2.5 volts and draw about 20ma.
I'm still very new to the world of "home brew" electronics so I may need to request that any help be followed up with greater clarification.
Thanks in advance,
John
Thanks in advance,
John
