Try removing the cap on pin 5, leaving pin 5 open. It is optional anyhow. Voltages. Assuming the battery is 9V (bad assumtion, 9V batteries are pretty unstable over the long term, but the 555 is designed not to care), pin 5 is 1/3 Vcc, or 3V. Pins 2 and 6 (same point) are between 1/3 and 2/3 Vcc, and should be shifting, and Pin 7 is higher than pin 6, until it conducts (1/2 of the cycle) and it goes to ground. It is possible that pin 7, which is a switch, is blown, a common problem.
This article, CMOS 555 Long Duration Minimum Parts LED Flasher, shows how this oscillator works. Other than not having a LED resistor (which is a specific property of the CMOS 555 and low battery voltage) it is very similar to your circuit.
