led project
nitro22
Joined Jan 26, 2010
14
hi guys im wanting to do a lil project with led's but i can not find a cheap source for flashing leds....would anyone no of a few places.....thanks for the help guys
nitro22
Joined Jan 26, 2010
14
thats a circuit to make them blink correct ?? im just looking for blinking led's so i dont have to build a few circuits
or should i buy regular LED's and build the 555 timer for tons of LED's ?? witch do u think would be better ??
bertus
Joined Apr 5, 2008
22,270
An 555 circuit will give you more freedom on how the leds are flashing.
(you can adjust the flash-rate and the flash-time).
Leds with biuld-in flash circuits will have different flash-rates that can not be controlled.
Greetings,
Bertus
Wendy
Joined Mar 24, 2008
23,415
Still after the double flashing circuit?
If you're just learning to do this I highly recommend a protoboard, it is much easier than soldering.
What part of the world do you live in? This dictates where you can get parts.
k7elp60
Joined Nov 4, 2008
562
Mouser Electronics, www.mouser.com has blinking LED's in stock for less than $1 each. Go to the website in search for blinking LED.
I have used blinking LED's in series with standard LED's to blink strings of LED's. Most of the blinking LED's that I have used will work on a fairly wide range of voltages.
retched
Joined Dec 5, 2009
5,207
Yes, blinking leds do, in fact, blink. However, with the minute difference in forward voltages from led to led, you will have a heck of a time if you want 2 or more to blink at the same time or rate. Using a circuit will give you control over all of that. And for 10 cents or less for standard LEDs, and $1 for blinkers, it depends on the finished project.
Are you using more than 1 led in your design?
