Led patterns
Discussion in 'The Projects Forum' started by twocorp, Aug 5, 2010.
  1. twocorp
    May 6, 2010
    5
    I was hoping to build something similar (different coloured lights to make a pattern, but using a rechargeable 9V battery) but am a little overwhelmed by your schematic and the discussion over the types of transistors.
    Can you tell me briefly just what purpose the Q1 - Q8 components serve?
    Can you tell me briefly just what the CR1-CR6 components serve?
    I note that you have a few capacitors, Pardon my ignorance, but someone told me they are only used in an AC circuit ?
    Any pointers would be appreciated.
    Thank you
    twocorp
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I assume you are talking about this schematic...
    The transistors are part of a current regulator design, the diodes are voltage references for the transistor circuits. They set the lower limit. I drew this quite a while back.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    A rechargeable 9V battery can light the 40 LEDs for about 10 minutes before it needs to be re-charged. The LEDs will slowly dim during the 10 minutes as the battery charge runs down.
    If you make the LEDs very dim then a 9V rechargeable battery will last longer.
  5. twocorp
    May 6, 2010
    5
    Thank you
    twocorp
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
