LED optical power
Discussion in 'Homework Help' started by rajiv.ganti, Oct 16, 2012.
  1. rajiv.ganti
    Jun 2, 2012
    Hello all,
    I am involved in one thesis task. I am using "FC300R-120" LED that has following characteristics:
    Max. forward current= 100mA
    forward voltage between 1.7v-2.3v
    and Datarate of 250Mbps.
    According to the specifications, the -3db optical power is achieved at 100MHz frequency at 20mA bias.
    Now my task is to use any simple circuit (for example: RC circuit) added infront of LED to increase this -3db optical power achieved at 135MHz or 150MHz instead of 100MHz.
    The curve should be linear.
    As per specification the above mentioned 100MHz -3db curve looks like the 1st graph that I attached below.
    And now, I should make a lump at 100MHz using this "simple circuit" so that the -3db falls at later frequency range. (I ve drawn the approximated circuit and attached as 2nd image.
    Can someone please help me/suggest me how to proceed with this?
      File size:
      26.6 KB
      14
      File size:
      35.6 KB
      10
  2. crutschow
    Mar 14, 2008
    13,482
    3,369
    You configure the RC as a high-pass filter that has a corner frequency of about a 100MHz. You place that in parallel with a resistor to provide a constant gain below 100MHz.
  3. rajiv.ganti
    Jun 2, 2012
    I have a small query..I attached an image titled "01.jpg". If you open it, you can see two wave forms, one is the "small-signal frequency response" vs "capacitive load" and the circuit diagram is also included.
    I would like to know how does the resistor 'Rs' and capacitance 'Cl' effect the transfer function of the Op-Amp. In other words, I would like to know clearly the function of this resistor and capacitance.
      File size:
      82 KB
      9
