Led on switch turning off in on position
Discussion in 'The Projects Forum' started by shezza, Jun 22, 2014.
Thread Status:
Not open for further replies.
  1. shezza
    Mar 19, 2014
    45
    Hi all,
    I want to buy a 3 pin switch with an led.
    I want the led to notify me that the switch is in the open position, not closed.
    Any thoughts as how I would do this? Im stumped...
    Guessing its something easy, but that doesnt mean I can work it out :)
  2. Billy4184
    Member
    Jun 20, 2014
    31
    A 3 pin has two closed states so connect a resistor and LED from the OFF pin to the ground and connect your equipment to the opposite (ON) pin. And connect the power to the middle pin.
    EDIT: misunderstood you. So just connect the power to the middle and a resistor to ground on the side that has the LED. Connect your equipment on the pin opposite the LED.
    Make sure the resistor that goes to ground is the same as the LED series resistor for the voltage you are using.
  3. shezza
    Mar 19, 2014
    45
    A 3 pin without an internal led has two closed states. Though with an internal led, there is only one closed state I believe. The third pole is for the + of the led.
    I really wanted one with an in-built led rather rather than an external led. If I have to, then I guess I will live, but there must be a way? Or are there 4 pin switches with an in-built led and two closed states?
  4. Billy4184
    Member
    Jun 20, 2014
    31
    Sorry I'm a bit foggy (should have drawn a diagram first!) I don't think it is possible as the off position does not have a terminal out as far as I know. So maybe just hook up your own LED with a two-closed-state switch.
    Why do you need the LED on when it is off? Just read things the other way around...
  5. shezza
    Mar 19, 2014
    45
    Well the external led was my first thought, but it would just be cleaner with an in-built one.
    I have an auto windows up module in my car for when I leave my car. I am installing a cut off switch in case I want to leave the windows down. Though I want to make sure I remember to re-enable it to not end up leaving my windows down when I want them to go up.
  6. DickCappels
    Aug 21, 2008
    2,766
    667
    Easy:
    1. Connect the LED to its power supply through the current limiting resistor.
    2. Connect the switch in parallel with the LED.
    When the switch is closed current to the LED will be shunted around the LED by the switch.
  7. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Pity you mentioned 'car'. Are you aware car mods are banned on this site? Read the Terms of Service.
    Why would you want to leave the windows down? Chances are you wouldn't have a car to return to :)
  8. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics.
    The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
Thread Status:
