LED on 1sec after power supplied to it
Discussion in 'The Projects Forum' started by Faris1985, Dec 8, 2011.
  1. Faris1985
    Nov 29, 2011
    7
    I want to turn on an LED 1 sec after power is supplied to it and the LED should then be on until power is disconnected. Pls provide the schematics if possible
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    How close does the timing on the 1 second need to be?
    0.9-1.1 seconds OK?
  3. T.Jackson
    Nov 22, 2011
    328
    14
    Lol. Round 2 of insanity. You do something with relays then I'll come with something solid state using an MCU.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    I abhor relays.
    I'm thinking an RC setup on the base of the driving transistor, which will be +/- 10% on accuracy, but very simple.
  5. T.Jackson
    Nov 22, 2011
    328
    14
    I'm thinking about a sanity check for some people.
  6. Faris1985
    Nov 29, 2011
    7
    Yeah close to 1 sec
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    A very similar project...
    Power led slot turn
    If you have any questions about it post them here, on this thread.
  8. wayneh
    Sep 9, 2010
    12,382
    3,238
    I think this is more-or-less what was suggested above. I have NOT done the math on the timing, the cap and resistors, I just took a wild guess.
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    With those base resistor values I doubt it will get close. In the end the transistor needs to be in saturation.
    I don't know if the OP is wanting fading or not, which is the circuit I pointed to. If just a delay a 555 or other Schmitt Trigger is probably the ways to go, as it addresses the fundamental gain issue.
  10. sheldons
    Oct 26, 2011
    616
    101
    this can be built quite small ,you may need to play with the values of the timing components to get what you need....
