led night light from Lidl
Discussion in 'General Electronics Chat' started by Stratos15, Jul 10, 2016.
Thread Status:
Not open for further replies.
  1. Stratos15
    Aug 23, 2015
    6
    I have bought a led night light from Lidl.
    Its characteristis are:
    LIVARNO led night light - Model No: 100933-14-04
    230V-50Hz 0.30W Max
    LED: 1 x 0,18W Max
    When plugged in to the mains, it was changing colours during the night. Lately it stopped working and only the red light is showing up and it is dim.
    I opened it up to check which components it contains. These are:
    The led is WS2812B 5050, which I connected it to two AAA batteries and all led colours seem to change with no problem.
    I also connected the two AAA batteries to the integrated circuit, which send the pwm pulses to the led for changing colours, and seems to work fine.
    Lastly I plugged it in to the mains in order to test the bridge rectifier MB10S and returns DC current to the output.
    You can view photos here:
    https://www.flickr.com/photos/84601134@N06/28107860782
    Can someone suggest me what else I can check out?
    Thank you very much for your help.
    Regards,
    Stratos
  2. AlbertHall
    Jun 4, 2014
    2,285
    451
    This looks to me like a capacitor input mains supply with a problem which we are not allowed to discuss in here.
    Sorry.
  3. DickCappels
    Aug 21, 2008
    2,786
    676
    This cannot be discussed on allaboutcirucits.com
    1. Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
      • Any kind of over-unity devices and systems
      • Devices designed to electrocute or shock another person
      • LEDs to mains
      • Phone jammers
      • Rail guns and high-energy projectile devices
      • Transformer-less power supplies
      If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
Thread Status:
