LED Neon Lamp
Discussion in 'General Electronics Chat' started by Helena123, Apr 16, 2014.
  1. Helena123
    Apr 15, 2014
    7
    I'm doing a small project and I was wondering if there was any possible way to replace NE 2 neon lamps with LEDs.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Depends on the circuit. We do not allow LEDs connected to mains (live AC voltage) on this site. However, if you show us what you are trying to do I am sure we can help.
  3. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    That's a little vague!
    The 2 devices have wildly different voltage requirements, you can get LEDs that work as low as 2mA, which is in the ball park of the heavier rated neons.
    You'll need a voltage dropper, and if you're running it from AC; you'll need to either use an inverse parallel pair of LEDs or a single LED with an inverse parallel 1N4148 to protect it from reverse breakdown.
