This is a LED lighting project that will go into a high power rocket shaped like saucer. Because this is a high power rocket, it must be launched at a certain distance from spectators for safety reasons. The launch pad will be at least 200-300 feet from spectators and rocket may go as far as 1000 feet from the ground. Flashing lights are easier to see than non-flashing lights. Lights flashing in a pattern are even easier to see from a distance and this is why I'm doing a LED matrix.
I'm currently in the preliminary planning stage. Things to think about for this project:
1. Lights will be on for a maximum 1 to 1.5 hours.
2. The power supply will be a lithium polymer pack outputting a maximum of 16.8V.
3. Matrix will probably be 16 columns x 8 rows. (this may change)
4. Lights need to be bright enough to be seen from a distance.
5. Saucers use aerobrake recovery rather than parachute recovery, so the whole circuit needs to be light.
6. Would like flashing pattern to be changeable via a pushbutton.
7. A voltage cut-off circuit will be needed to prevent over discharging the batteries.
I'm posting my project here so that I can get some help with it. The circuit I'm thinking of using is described here: http://www.instructables.com/id/LED-matrix-using-shift-registers/step1/Parts/
The time the lights will be on may actually be around 30-45 minutes, but I put down 1-1.5 hours as the outside estimate. There are so many LED's out there that I don't know which ones to pick. If any of you have ideas, I'm open to suggestions. I would think a high viewing angle and high brightness coupled with lowish current and voltage would be best.
Also, I'm not familiar with the HEF4794B and MIC2981/2982 chips. I could use a tutorial on how they work.
Here are some pictures of my saucer fleet and the big pink one lifting off on a K185 during a daylight flight. Also posting a picture of the circuit I'm thinking of using. If you think another circuit would be more suitable, please let me know.
Your help is appreciated,
Mike
Mike
