LED lights conversion: Need a new circuit. PLS HLP!
Discussion in 'The Projects Forum' started by jomeza001, Jan 23, 2014.
Thread Status:
Not open for further replies.
  1. jomeza001
    Jan 23, 2014
    **To moderators: Can you please move this to "The projects Forum" ?? Tnx in Advance.
    From factory my 2004 Jeep Wrangler comes with ordinary, 2 filament bulb up front. I have converted to LED lights with only two wires (Neg, and Pos).
    So the goal is to get the LED Lights to:
    1.-LED's to Blink when the turn signal lever from the steering wheel is activated
    2.-LED's to run at full power while the marker lights are on
    3.-LED's to blink on turn signal even when the marker lights are on.
    The image below shows a relay configuration someone posted in a Jeep forum. It works great *ONLY* when the marker lights are ON. This means during the day, this circuit leaves me with no turn signal lights.
    Here the details:
    So my quesiton is... what do you suggest to achieve to light up the leds as turn signals but during the day when my marker lights are off???
    Any question will be appreciated!
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
Thread Status:
