Hello Everybody!
The project is a 3 foot long 48 common anode LED RGB lightbar controlled by software PWM using a PIC MCU.
Here is the current PCB layout...
.48 inches wide and 12 inches long.
http://img245.imageshack.us/img245/7070/ss20090603175454.png
Do I need a grounding plan on the PCB to prevent broadcasting interference to other electronic devices?
Another concern is the trace widths... each color will consume a max .96 amps @ 5v and the traces are 0.039 wide... is this enough width? How long can I run the trace with out resistance or voltage drop effecting the LEDs output? Note: the positive is slightly wider and is doubled. (one trace on top and one on bottom)
-Prop-
-Prop-
