Last night wandering thru Lowes I spied a LED array lamp sold as a replacement for a 12V 10W halogen. Now since I have several lights of this type in my kitchen that never work as they burn out too frequently to keep up with (and they ain't that cheap either even from IKEA) I bought one of these as a replacement:
Out the door for $8.98. That's cheap if I never have to replace these. I still have to test the importaint thing: how good is the light? It's a nice warm color but with a 67 lumen rating will they be bright enough compared to a 10W halogen which has a rating of 160 lumens. I'll test that tonight in my kitchen at night.
But first let's tear this sucker down! There's no case per say to open, the device is a white PCB with parts surface mount attached. The wires sticking out the back appear to be heat sinks, the pins are all common but unconnected to the rest of the circuit. Each pin has a tab going under a LED to form a thermal path.
The board itself was very dirty! I could see lots of obvious flux residue, and stuck in this were some black fibers. I couldn't read any part numbers on the ICs till I cleaned it.
Just from the outside measurements it's a nifty circuit. It runs bidirectionally so either polarity DC or an AC are good. Current draw at 12VDC is about 130mA, and there is current limiting so even up to 20V it still draws 130mA. As the part heats up this current does drop some, so there is good thermal regulation too.
Here's what I pulled out as a schematic:
No suprises here. U3 is a bridge rectfier for AC use. U1 and U2, whild unidentified parts have to be current source regulators; their output tops out at 9.6 VDC. All LEDS are in 4 parallel chains of 3 LEDs each for a total of 12 LEDs.
If anyone is good decoding top marks the regulator has an L2, small underlined S, and the number 11 on it's side like so:
Links:
LED light at Lowes
LED at Lexxus (manu)
Links:
LED light at Lowes
