I'm planning on buying 12VDC SMD3528 LED strip lights, such as these: Amazon.com: HitLights Cool White Double Density 600 LEDs Flexible Light Strip, 3528 Type SMD, 5 Meter or 16.4 Ft, 12 Volt, 48 Watt: Home Improvement
This will be used to light a cabinet. The entire LED strip is 48W, so 4A on 12VDC. I want to use the entire 16ft, but partition it into 4 pieces: 3x1ft sections and 1x13ft section. The shorter sections would be to light up individual shelves, while the large section would go around the inside of the door frame.
Can I wire these like so:
Hopefully the above diagram makes sense. Basically, I'd like to split the power lead coming out of the switch into 4 leads and drive 4 LED strips. Would this plan work?
In terms of splitting the wires, I'm thinking I'll solder some wire to the coming off the switch. What type of wire is appropriate for this? 18 gauge? 22 gauge? Should it be copper or is copper clad aluminum suitable?
Also, should I solder all 3 additional leads to the first wire in the same spot, or solder each of them to the main wire where I need them to branch off? I.e.:
