LED light panel help?
Discussion in 'The Projects Forum' started by hawkins990, Sep 27, 2012.
  1. hawkins990
    Sep 26, 2012
    I am getting a 100w led driver with 32 - 36v output, 500 red diodes, wavelength 660nm with forward voltage of 2.0 - 2.2 and forward current of 20ma. I know that I can use an led calculator to determine what size resistor and wiring diagram but how do I know how many LEDs I need to use 100w?
  2. mcgyvr
    Oct 15, 2009
    4,793
    976
    um is it a crappy chinese "constant current" driver... I bet it is...
    please post a link or specs to the driver.
  3. hawkins990
    Sep 26, 2012
  4. KJ6EAD
    Apr 30, 2011
    1,426
    364
    You need 2381 LEDs (100W / (2.1V X 20mA)). If you use that constant current supply with only 500 LEDs, you'll have to waste 79% of the available power heating resistors!
  5. hawkins990
    Sep 26, 2012
    Thank you for the help! Wow 2000 eh? That's a lot of soldering haha
