LED light organ
Discussion in 'General Electronics Chat' started by reno12469, Jan 18, 2009.
  1. reno12469
    Thread Starter Active Member
    Jan 17, 2009
    47
    Is it possible to have a 12v LED rope light hook up to an LED light organ in a car using the 12v car battery? I found something that is similar but works with 4 LEDs and i was wondering if you could hook up the rope light to it.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
  3. reno12469
    Jan 17, 2009
    47
    Ok. Would it work with a 48" strip that contains 60 blue LEDs and operates on 290-400 mA @ 12Vdc?
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    You could replace the transistors 2 4 and 6 by 2n2222 types.
    The 2n2222 can handle the current you require.
    Greetings,
    Bertus
  5. reno12469
    Jan 17, 2009
    47
    Is it possible to have two of the LED rope lights hooked up to it?
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    Then you will need a more powerfull transistor.
    Something like a darlington transistor like a TIP120, that can handle upto 4 A.
    Look afther cooling the transistor.
    Greetings,
    Bertus
  7. reno12469
    Jan 17, 2009
    47
    Thank you.
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    The color organ circuit drives only a single LED on each of its driver circuirts. It will not drive a rope light that is a series string of LEDs.
    It can be modified so that each driver can drive its own rope light.
  9. reno12469
    Jan 17, 2009
    47
    Can you show me how or tell me?
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    The Hobbytron product does not have a schematic and the German site is asleep and does not open.
