LED Light Gradient
Discussion in 'The Projects Forum' started by nDever, Feb 28, 2015.
  1. nDever
    Thread Starter Active Member
    Jan 13, 2011
    154
    Hey,
    For a display application, I need a strip of leds that exhibit a 'light gradient' effect; when any one of the leds are lit, the light from it spreads out on both sides and gradually fades.
    I designed this circuit to do the effect; I also did the simulation, and the circuit did what I needed. The black box in the lower part of the diagram is a decade counter. I just needed your guys' wisdom on this one. Am I over-engineering this one?
  2. Dodgydave
    Jun 22, 2012
    5,167
    777
    No, under ,there are no resistors in series with the leds from the diode outputs,ideally use 100 to 470 ohms.
  3. nDever
    Jan 13, 2011
    154
    Oops...JK guys, I was just seeing if you were paying attention! :D
    Dodgydave likes this.
