LED light array
Discussion in 'General Electronics Chat' started by electronewb, Nov 11, 2012.
  1. electronewb
    Apr 24, 2012
    260
    I do camera work and I'm thinking about building an LED panel so I can light up the subject while I shoot I was thinking of using single LED lights until I found this 300 LED strip.http://www.ebay.ca/itm/5M-Black-PCB...809743?pt=US_Car_Lighting&hash=item19d69d368f
    Supply voltage would be 14VDC How many of those LEDs on the strip can I use before I start frying them?
    My idea would be to cut the strip and to use a project box with white or silver perforated board But how many
    LED's could withstand 14VDC??
    One more thing the supply for the strip is 12VDC @ 3A My supply is 14VDC would I need a voltage regulator?
  2. spinnaker
    Oct 29, 2009
    5,062
    1,160
    Forget about the individual LEDs or even the strips. That is a lot of soldering and you can't be guaranteed you will get a batch of matching LEDs unless you buy a few thousand an sort them out.
    Look at something like one of these instead.
    http://dx.com/c/home-garden-1099/lightings-1045/led-light-bulbs-1072
    These bulbs have current limiting so you won't need to worry about building a buck regulator.
  3. electronewb
    Apr 24, 2012
    260
  4. electronewb
    Apr 24, 2012
    260
    Would the 14VDC supply be bad for the 12VDC that the strip needs to work
  5. spinnaker
    Oct 29, 2009
    5,062
    1,160
    It's not the voltage you need to worry about (assuming you exceed the forward voltage of the led enough to light it), it is the current. If you connect a battery to the LEDs they will light but if current is not regulated then they won't last very long.
    I am not sure if those strips have current regulation or not. Form the looks of it, I would say no but then again I am just learning about these new products myself.
