Not sure I am following you. What do you mean by "certain" points.You can black box it by setting putting the 700mA buck puck on the power leads, then measuring voltages at different points. You'll then be able to tell what the internal routing and layout of the board is since all of the LEDs are roughly the same Vf, certain points will show Vin, resistors, then how many Vfs before you hit ground on various pins.
Granted, it's not fast, but short of taking it to a courthouse X-Ray machine and asking nicely, there isn't a way to see the connections. Though applying more aggressive dis-assembly of the sacrificial unit would also work if you don't want to spend that much time (or if you don't know a courthouse guard).
Power supply looks decent, a lot of features for the price!Not sure I am following you. What do you mean by "certain" points.
BTW I do intend to order this supply:
http://www.circuitspecialists.com/bench-power-supply-csi3303s.html which has current limiting.
I was thinking if you tested out points on the spiral PCB pads, you could find how the LEDs are actually connected. Then you could run it on a lower supply voltage by soldering in new wires where applicable.Across the supply leads? I should measure voltage at the pads? What would that tell be exactly again? How many should I measure?
YOu must ask the dealer to replace the lights. As it will cause problems in futureI ordered a few of these
http://dx.com/p/gu5-3-3-5w-6500k-420-lumen-60-led-white-light-bulb-12v-131888
from Dela Extreme. I hooked them to my homemade LM317 power supply (it has no current limitation). I connected an amp meter and measured over 1 amp.
I assumed these bulbs had their own current regulation but they are advertised at 3.5W
At 3.5W I should only be drawing less than 300 ma correct?
Am I correct to assume they don't have current regulation?
Thread starter | Similar threads | Forum | Replies | Date |
P | Signal lamps | General Electronics Chat | 16 | |
K | Germicidal lamps | General Electronics Chat | 8 | |
H | Converting 3 x 1.5v led lamps to 18650 batteries | General Electronics Chat | 3 | |
False Triggering from Fluorescent Lamps? | Analog & Mixed-Signal Design | 6 | ||
How to run this HV lamps? | General Electronics Chat | 3 |
