Hi, this is my first post, hope you can help. I'm an industrial design student, fairly inexperienced in electronics, though I have soldered circuits together before, and I know the very basics (V=IR, what a capacitor and resistor and PCB are).
I'm wanting to make a reading lamp, with the light source being a small array of LED's with output of about 400lumens in total, and area of about 35X25mm. It will be powered by mains power, via a plug-in transformer. DC or AC, I don't really know the pros and cons. The switch will be in the power lead initially, though I am interested in perhaps making a passive infra red switch, (waving hand in front of light for on or off) or capacitive switch using the metal housing.
The light doesn't need to be dimmable, and doesn't need the capacity to flash or anything like that.
I"m wondering where to start with all this. Can I buy an array of LED's off the shelf, with a choice of AD/DC, voltage, power, and just solder up 2 wires, or is it more complex?
Thanks in advance for your help,
Andrew
Andrew
