tkng211 said:Suggest you replace the resistor R2 with a 1K Ohm trimmer connected in series with a 220 Ohm resistor (or experiment with different values of resistor, 560, 680, 820, 1K, 1.2K, 1.5K) to see how it affects the performance of the LED. After you get a more satisfactory result, you can further adjust the value of R1 to get better result if possible.
Make sure that the transistors are connected correctly and the LED has not been damaged by the reverse voltage from the inductor. Maybe you can also add
a diode 1N4148 connected in parallel with the LED but in reverse direction to protect the LED from breaking down by the reverse induced voltage .
Actually, I think tkng211's suggestions were referring to the original circuit that electronicsnewbie posted in his opening to this thread.The components selected for this circuit I posted are optimum for its efficiency any deviation from the circuit could result in poor performance/and or low LED luminosity.
hgmjr
