LED Intensity
Discussion in 'General Electronics Chat' started by RodneyB, Aug 18, 2014.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    654
    14
    I am trying to understand which LED is brighter and why
    I have one and the datasheet shows an LED 585nm 3KR , 583nm, 10mcd, 120 DEGREES
    The second LED datasheet shows LED SMD 1206 CL-YL 180m 60D 3K SURFACE MOUNT LED, 1206, CLEAR YELLOW 595nm, 180mcd, 60 DEGREES
    My understanding is the higher the mcd value the brighter the LED is that correct. I am getting so much mixed information I am lost.
  2. Benzodiazepine
    Aug 17, 2014
    17
    Yes MCD (Millicandella) -- denotes brightness. The degrees is the viewing angle. How far the light spreads.
  3. wayneh
    Sep 9, 2010
    12,406
    3,256
    Note that you can quote a very high mcd value if you use a lens to focus a narrow beam. This makes it hard to compare values when the dispersions angles are different.
  4. KJ6EAD
    Apr 30, 2011
    1,426
    364
