Hi folks,
I'm trying to build a simple LED indicator for a hobby project, but while I know a few basic things about circuits, I'm a little out of my depth and need some help working out what's possible here.
I've found some designs online that are close, but they're not quite what I need and I'm wondering if a simpler circuit is possible. The best examples I've found so far are these two, a voltmeter, and a low voltage indicator:
http://www.electroschematics.com/5816/led-volt-meter/
http://www.rmvhf.org/wordpress/?page_id=889
What I really want is this:
- I'm testing a single cell LiPo battery, so the possible voltage range is 3V to 4.2V
- I'd like a green LED to light up if the voltage is over 4.1V (easy!)
- I'd like a red LED to light up if the voltage is below 4.1V
From my reading online I know I can create a low voltage indicator using zener diodes, but I'm wondering if a simpler design may be possible, and whether I can use the green LED lighting as a means of extinguishing the red LED.
It feels like something that should be possible, I simply don't have the knowledge to know if it is, or how to design it.
Thanks all,
Myx
Thanks all,
Myx
