I have the following connections:
0V, 12V switched, and 12V.
I want to install a pair of LED's that indicate in the switched 12v is on or off.
I was thinking along the lines of the following:
0V - neg of LED1,
switched - Pos of LED1, NEG of LED2
12V is Pos of LED2
Would this work in principle? would LED's be OK if it received 12V on both legs?
Where would i place resistors? Would i need a set in the switched and 12v? or could i get away with just in the switched?
0V - neg of LED1,
12V is Pos of LED2
