hi
if i connect this ,will the density on each LED be the same ?
And if you'd want to gild the lily... then individual current control would be the thing, that's always the best (and most complicated and expensive) way to drive an LED...The answer is NO. Bertus is correct; furthermore, depending on the brightness matching you desire you will have to adjust each series resistor to obtain the matching. That said, they won't stay matched (depending on your definition of matching) because temperature, age, voltage variations, etc. will cause brightness changes.
