LED help
Discussion in 'General Electronics Chat' started by splitg2, Jan 22, 2011.
  1. splitg2
    Jan 22, 2011
    OK, so I wanted to buy some super bright LED floodlights for around my house. Imagine my surprise when I found out they would cost over $250 a unit. I have a streamlight stinger rechargable flashlight that its beam easily shines 300 yards and cost me $50. So here is my question. Why do the home units cost so much???? Thanks for the help, Newbie "Splitg2"
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    That flashlight you have is now selling from $85 to around $130.
    I'm sure if you wait long enough, those LED floodlights will get a lot more expensive.
  3. spinnaker
    Oct 29, 2009
    5,081
    1,180
    Sorry to hijack the thread but why are they getting so expensive? Just the popularity of LED lighting? Or is there something else going on (other than the US dollar going into the toilet. :) ).
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, the dollar IS in the toilet. Haven't you noticed the price of things going up over the last decade?
    Pretty soon it'll be cheaper to make things here than buy them from abroad. But, that's the idea.
  5. maxpower097
    Feb 20, 2009
    795
    388
    Lifespan of an LED can exceed an normal flashlight by years sometimes. And when it comes to mounted lighting professionally installed having to change the bulbs yearly vs every 5 years could make the difference in price. Plus you get a lot more light vs power with LED's then Flashlights. This is purely speculative but could be the reason. Its like the mini Flourescent lights vs incadecents. 100w vs 13w = same light.
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Durability, focus, and run on a CR123 battery for a long while with a built in buck-boost converter. Throw it down onto concrete, 10 times? Drop it in a lake and need to go diving to pick it up? No Problem, they keep working.
    I usually have the tailcap switches break after a few years before anything else other than a bi-monthly battery change goes wrong. Mine are Surfire, but Streamlight has some higher end lights as well.
    I speak plural because I keep getting the next highest wattage offered. The big LED outshines non-HID headlights, and it is the size of a Bic Lighter!
