led help needed
JeffSchaber
Joined Mar 14, 2013
12
My guess is that even though there are provisions for two batteries, both batteries are in parallel and must be the same voltage. Without a schematic of the PDB, I can't be sure of that, but it seems logical.
I sent a question to the people that sell these hoping they can answer this, otherwise I'll hook a meter up to it tonight when I get home.
If I end up with a custom designed board, this shouldn't be an issue.
Markd77
Joined Sep 7, 2009
2,806
The resistor had the number 151 stamped on top of it so I'm assuming it's a 151 ohm resistor?
Pretty close, it's a 150 ohm resistor, just by coincidence.
The last digit is the number of zeros to add on the end of the other digits so:
150 = 15 ohm
151 = 150 ohm
152 = 1500 ohm
etc
tracecom
Joined Apr 16, 2010
3,944
Jeff,
Attached is a picture of your controller with hook-up information. I'll put it in the mail to you on Friday, 3/22/13.
It has been working flawlessly for 6 hours, so it should be solid.
I'll try to shoot a video if time permits.
ETA: No video, no time.
JeffSchaber
Joined Mar 14, 2013
12
Jeff,
Attached is a picture of your controller with hook-up information. I'll put it in the mail to you on Friday, 3/23/13.
Charles, I owe you more than thanks! I really could not have done this myself and appreciate your willingness to help me out. Tell me what I owe you for your time , trouble and parts and I'll send it your way!
Thanks again!
