Led Grow Light
Discussion in 'The Projects Forum' started by TomatoMan, Oct 17, 2011.
  1. TomatoMan
    Oct 16, 2011
    39
    Hello the question I would like to ask is about wiring and powering a grow light. The light I am building will be made up of 3watt high power leds. I will be surface mounting these to a sheet of aluminum. I searched the other grow light post here but did not find one that would answr my questions. I will be using 50 red 2.6-3 volts, 10 blue 3.6-4 volts, 5 cool white 3.4-3.6 volts, and 5 warm white 3.4-3.6 volts. I am a total noob about Leds and would like to know the best way to wire them. Should I keep all teh red in one series and blue in its own ect? Also what should I use for a power supply for this light? Thanks for any help you people can give.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    The subject has come up quite a few times here on AAC. I have helped with several projects, but no two are quite the same.
    Since you are dealing with power LEDs you MUST mount them to a heat sink, a chunk of aluminum to soak the heat generated by the LEDs away. This is critical.
    The second thing you need to work on is to find a power supply that will drive all those LEDs. You can use a 12V power supply, I believe a 24V is better. It needs to be very beefy. You quote 50 red LEDs, that means it is going to have to be larger than usual, that or you're going to need multiple power supplies. You will likely need around 250-300W of power. Power is volts X amps.
    After you have a power supply picked out I can help you design something to drive the LEDs. You will likely have to build some electronics, there really isn't a way around this, but it will be relatively simple. You will also need a DVM.
    I am not in front of my computer, when I am I will point you to some other thread. The reason is there has been a lot of discussion about what the best color mix of LEDs to use. I suspect you will be interested in the subject, you are not the first person (or the 10th) to come to this site to discuss the subject. Your's sounds like the biggest to date however.
    By the Way, Welcome to AAC!
  3. TomatoMan
    Oct 16, 2011
    39
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    That would work well, but it is a bit pricey. I would keep on looking if I were you. Not too long ago you could buy a 24VDC 6.5A power supply for $14. You could use a computer power supply, but all the odd voltages will be a pain to work with.
  5. mcgyvr
    Oct 15, 2009
    4,791
    976
  6. iONic
    Nov 16, 2007
    1,422
    68
    Here a power supply for half the price.
    Switching Power Supply
    You'll be able to string 6, 7, or 8 LED's together.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    The two posts above offer good options. Let us know what you want to do. The offer is to help design a LED driver is still open, but unless you have some experience building electronics, premade is a much better deal.
    LEDs are pretty basic electronics, but there are no shortcuts.
    I've written a tutorial on LEDs and special effects for beginners. For a total beginner it may be confusing, but hopefully it will get the point across.
    LEDs, 555s, Flashers, and Light Chasers
    One of the core subjects about using LEDs for grow lights is the exact mix of colors needed. There are a lot of opinions on the subject. I have no opinion myself, don't know anything about the subject.
    Here are some other threads where it came up...
    Help with LED grow lights
    300W LED Grow Light
    Need help with simple LED grow light circuit: Cash reward
    Simple LED Project
  8. TomatoMan
    Oct 16, 2011
    39
    Thanks for all the replys. The link for the reef light set up that mcgyvr posted is the type of set up I am looking to do. Is the power supply in ionic's link enough to power 210 watts of leds? Mr Marsden you blog entry was great very detailed even for a noob it is great you took so much time to write the piece. On the point of building or buying I already have purchased the leds. I know I should have inquired first about wiring and powering before the purchase but I did get a nice deal. I bought 420 watts of leds 140 pieces for $210.00 shipped. I will be building two lights so I will save a great deal of money dying the light. Although I don't have much electronics knowledge I am handy and can follow instructions well. I think with help from the knowledge and help from the members of this forum I should be able to pull it off. On the point of this forum and otthers, I am amazed with the readiness of people who never meet each other to help each other. If the outside world in face to face life was like this it would be so much better. Mr Marsden seeing as I put the cart before the horse in buying the leds already I will take any help you can give on mnaking this light happen. Thanks again
  9. iONic
    Nov 16, 2007
    1,422
    68
    The Supply I pointed to is just one of many that this supplier has. The specs are:
    Output: 28Vdc / 9.0A. (unrestricted convection cooling) or 28Vdc / 12.5A (26CFM forced-air cooling)
    The power is between 250W - 350W depending on the addition of sufficient cooling. And even if you did use fan cooling I would not push it past 300W.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Looking at it the Reef LED power supply would be ideal for your application, if it has enough outputs.
    One of the things we often do here is point out off the shelf solutions. Your application is a bit larger than most, so it is likely you would need more than one of the units, even with one that can drive 40 or so LEDs. My suggestion is to contact the company and ask.
    If you decide to DIY the power supply shown in post #6 is ideal. It will be much cheaper to build it yourself, but it will get very hot. The other companies probably doesn't.
    There are types of circuits we do not allow on this site. Without knowing for sure the aquarium companies drivers probably come under that heading.
  11. mcgyvr
    Oct 15, 2009
    4,791
    976
    2 BIG differences in the supplies I posted versus iONic's..
    Mine are "constant current" supplies specifically for LED's versus he posted "constant voltage" supplies.. Before you go any further you MUST know the difference.
  12. TomatoMan
    Oct 16, 2011
    39
    I will need a constant current power supply per Manufacturer's specs. I looked over some of the drivers at the site you posted mcgyver not sure whcih I would need. The prices at the site seemed a little higher it looked like the one for my needs could run well over 100.00. Mcgyver did you look at teh ebay link I posted? Do you think the drivers at the reef site far exceed the one on the ebay listing? I am have been working on a hybred tomato for the past year using outside growing and inside HPS in the off season. The HPS was putting out to much heat my plants were not happy. I am very close with my cross have the appearence but wrong taste at this point. That being said if I succeed I may have to name the variety after one of you LOL.
  13. iONic
    Nov 16, 2007
    1,422
    68
    TomatoMan,
    What's the (If) Typical Forward Current for these LED's???
  14. TomatoMan
    Oct 16, 2011
    39
    ionic led supplier stated 750mA on all four colors Blue, Cool white,Warm white are 3.0-3.6V and the red is 2.6-3.0 volts
  15. mcgyvr
    Oct 15, 2009
    4,791
    976
    yes its a constant voltage supply. which won't work without additional current limiting circuitry. Meanwell drivers are EXCELLENT quality. I use 2 at home on my reef setup (2 x ELN-60-48D).
    The link I showed has multiple variations and lists which meanwell you will need to use. I believe your needs fit into one of those options.
    Quick answer is I would use 2 x PLN 100-48 and do the second to the last wiring configuration (twice) splitting your light into 2 circuits essentially.
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
    Have you used their stuff before?
  17. mcgyvr
    Oct 15, 2009
    4,791
    976
    Who's stuff?
  18. Wendy
    Mar 24, 2008
    20,772
    2,540
    Never mind, I see where you stated you did.
  19. TomatoMan
    Oct 16, 2011
    39
    Mcgyver I checked out the Mean Well driver at 68.00 each I would be at 140 in drivers. I was wondering if there may be a cheaper option at this point. Again I thank you guys for all the help
  20. Wendy
    Mar 24, 2008
    20,772
    2,540
    Depends on how much your personal time is worth.
    Advantages with the Mean Well driver:
    1. They are much cooler. There will not be any waste heat to get rid of. I can not speak as to their effectiveness, if I used them I would still have a lot of questions to answer.
    2. They are simple. This may be a big advantage if you haven't done an electronic project before.
    Disadvantages:
    1. They are expensive. In spite of the diagrams they provided there is some question how many 3W LEDs per unit can be driven by one. If it turns out to be less than we originally thought then the price can go way up.
    Because of this this it is worth asking lots of questions before buying any merchandise. Call the manufacturer, tell them what you are doing, and see what they recommend.
    Advantages for the other route:
    1. It will be cheaper. Maybe a lot cheaper. I guestimate around $40, maybe more, but not a lot.
    Disadvantages:
    1. This is electronics, you will need to learn to use a DVM and some basics of electronics. You will get lots of help from here, but you are the man on the spot.
    2. It will get hot, very much so. As much as 200 to 300Watts of heat. Think space heater. If you live in a cold climate then this is not such a bad thing, but some how I don't think so.
    I mentioned it before, the aquarium site shows some examples of what I was talking about, but you will need to mount the LEDs on a heat sink to soak the heat away. It will be cooler than light bulbs, but still.
    A suggestion, you can go small scale and experiment with this before scaling it up, if you want to try building something. This way you can see what you are getting into before spending lots of cash.
