LED Flashlights on 12v
SteveDouglas
Joined Apr 30, 2009
49
I'd like to use the LED flashlights innards from Harbor Freight on the kid's PowerWheels cars for headlights. The cars are 12v, the flashlights require 3 AAA batteries each (4.5v).
What is the best way to power these from 12VDC ?
I considered using an LM317 regulator but seems like there's probably an easier, cheaper way ???
Thanks for any advice,
Steve
SteveDouglas
Joined Apr 30, 2009
49
right, thanks, I considered that but how do I know what wattage resistor to use ? I have a lot of 1/2 watt and 1/4 watt resistors on hand, I guess I could try the 1/2 watt.
Thx
Kermit2
Joined Feb 5, 2010
4,162
the lights won't be using very much current. I would be surprised if it exceeded 50mA.
1/4 watt should do very well.
KJ6EAD
Joined Apr 30, 2011
1,581
The light has 32 LEDs in parallel and will draw 640mA max if you give it 4.5V. These lights are grossly inefficient so it would do no harm to remove the internal limiting resistor and use an LM317 as a current regulator. It's easier to heat sink an LM317 than a resistor.
If I'm right about the current, you're going to need a 5W resistor (50% derated) doing it the way you plan (3V X 640mA = 1.92W).
panic mode
Joined Oct 10, 2011
2,761
my flashlight has fewer LEDs than yours and current draw is about 230mA. Best way is to measure, but i'm guessing you will have something in the 400mA.
Connecting two flashlights in series requires 9V. remaining 3 or so volt need to be dropped using resistor. I agree about easier mounting of LM317 but I don't think that would be best option because LM317 has 1.2V output plus about 2.5V drop which is already over 3V we have to deal with. Even if it is "there", it would be border line and offer no adjustment.
Resistor would be R=3V/current
if current is 360mA for example (0.36A) then resistor is 3/0.36=8.33 Ohm.
Standard value is 8.2 Ohm.
Minimum Power is P=I^2*R=0.36*0.36*8.2=1.063W so technically 1.5 or 2W could do the job. I'd rather stick with larger one (5W or 10W) just because they have larger area and will heat less.
Kermit2
Joined Feb 5, 2010
4,162
They are pulling over 250mA from an AAA battery?
If they are that power hungry then the internal battery resistance will cause the voltage to drop lower than 4.5V on three AAA. (new ones might hold up for a few minutes)
KJ6EAD
Joined Apr 30, 2011
1,581
The LEDs have a Vf of 3.4 to 3.6 so when you get rid of the low value limiting resistor in each you can wire the two lights in series using a regulator with a battery that is discharged to 10.5V.
The lights as "designed" will not draw 640mA because of the limited capacity and internal resistance of the AAA cells but when you give them a nice juicy gel cell to drink from they will.
Don't even get me started on the fact that each light has 32 LEDs in parallel!
An LM317T, a 68Ω resistor (>1/16W) and a heat sink is all you need.
Audioguru
Joined Dec 20, 2007
11,248
The LEDs in the cheap flashlight are all matched pretty well. If they were not matched then some LEDs would be very bright and burn out soon and other LEDs will be dim.
