I am attempting to make an LED flashlight utilizing 23-28 LEDs. The info on the LEDs is as follows: 25mA, 3.2-3.6v, 5mm, through hole. I am powering them with 4 c batteries in series for 6 volts and roughly 7800mAh. To limit current I am using 100 ohm, 1/4W resistors. Here is my issue:
The LEDs are to be mounted on a round circuit board(copper pads on one side, plastic on the other). However, since each LED requires a resistor it is near impossible to solder and connect the LEDs and resistors as required on the same round board because things are crammed in so tightly.
My questions: Would it be possible to have the resistors on a different board entirely? If so, would the extra wire needed to wire them together draw too much current(or would that be voltage?)? Also, if I were to use an LED driver, how many of these LEDs can be connected to one driver? By using an LED driver would I still need to use resistors(if so than using the driver would be useless for this application, wouldn't it?) Also, I have read the LED tutorial and was unable to glean much from it, so please don't post that link as an answer because it doesn't really answer my questions. Any help would be much appreciated!
Sincerely,
SBH
Sincerely,
SBH
