I am building a 9 LED flasher circuit with a 555 and 4017 and the first line in the chain output for the 4017 does not light up. If I lift the output from pin 3 of the 4017 to the MOSFET then the output from pin 2 does not work. When I say not working I mean it works but the LED is very dim. The remaining LED light up at full brightness.
I tried jumping between pin 3 and 7 and the led will light up full brightness when the sequence gets to pin 7 but it will light up dim for pin 3. I have replaced the 4017 chip and it still acts the same way.
