No, no, Im saying using the voltage divider as you did wont work. You shouldnt need it at all.
Take a 1k Ohm resistor and the wall wart. run it over the 1k resistor. What voltage do you read? If you measured the wall wart with no load, you will get quite a fluctuation. but It should calm down with a load.
You want to go from wall wart to 7812 to the rest of the circuit.
Completely skip the voltage divider.
