I have built an LED array and have it working fine. Only thing I have yet to resolve is some sort of control for the 2 12vdc fans I use for cooling. The LEDS are on an Arduino PWM controlled timed drivers. Because the fans are not they essentially run all of the time when I am not around to switch them on or off. I am considering a temperature controlled cct to control the fans. I have found the following project which appears to address my needs.
http://electronicdesign.com/article...l/dc-fan-controller-takes-bare-bones-approach
Any advice as to whether or not this would in fact do the job or is there a better way to do it? I dont want to spend a fortune, just want it to work.
If this works could I power both fans with one assembly?
Does this cct vary the voltage or the current to the fan?
If it varies the V and if my fans (muffin type) are rated at 12 VDC will it harm them to run with less?
